Discuss SWA Termination Exsposed Packing in the The Welcome Forum area at ElectriciansForums.net
Evening all, new member but looking forward to helping out where i can :)
When terminating SWA is it acceptable to have the “Packing” (the PVC between the armour and the single cores) exposed ?
I.E terminating into a box then having the packing exit the box leaving it exsposed and then enter into another accessory to be terminated. I hope this is understandable as not really sure how to explain it.
Thanks in advanced :D
It all depends on the environment and installation method the sheathed cable would be exposed to.
The application i am thinking is running SWA outside a house up the wall into the roof space and then terminating into a box and dropping the “packing” down into a switch for a shower. I know i can do this with PVC (T&E) but as the part of the SWA I’m referring to is called “packing” rather than sheath i was a bit unsure :confused:
Buy some PVc flexible conduit and run it down in that.
But it certainly does a better job than the conductors on their own for some mechanical protection and definitely better than putting a joint in it and taking T+E to the end point.
The other times this will be done is extending out from an FCU in a house to an adaptable box on the outside where the SWA is glanded in that box and the conductors in bedding are taken through the wall (preferably in a conduit) to the FCU.
As long as the run is very short and direct otherwise I'd be inclined to put it in flexi conduit.
Reply to SWA Termination Exsposed Packing in the The Welcome Forum area at ElectriciansForums.net
All of the work described below will be completed by a qualified electrician, I am just curious and using the info for planning!! I am planning a...
4K
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hi all, looking for a bit of advice and confirmation on my proposed plans for a SWA sub main to a ISO metal storage container. I've calculated the...
Good Morning everyone. Quick question regarding a sub main from a TNCS supply feeding an outbuilding on TT. This is a domestic installation not...
