Discuss Swimming Pool ceiling downlights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, is IP54 OK for down lights in an indoor swimming pool ceiling or does it have to be 12V? Thanks in anticipation, Rob
Why for christ's sake would an indoor swimming pools ceiling lights need to be 12 volt??
We generally use the typical totally enclosed plastic exterior flu fittings in such areas (including the swimming pool mechanical rooms). I'm pretty sure they are over IP 54, but then does yours need to be? Depends on what sort of ceiling heights you have in the swimming pool area. One thing here, i wouldn't be using metal light fittings in a chlorine vapour environment....
go for shower rated fittings if you like, no one can reach them anyway so all your attempting to do is keep moisture out of them.
just stick to 230 fittings
Reply to Swimming Pool ceiling downlights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm trying to understand legislation in the UK for using an air pump in conjunction with a swimming pool with regards creating and supplying...
So I’m an apprentice and only get to do downlighter jobs as foreigners at the weekend, but they’re typically added when the customer no longer...
Any ideas for an appropriate wall heater for school swimming pool changing rooms? (well detached from pool area but will still have wet bodies in...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
