Discuss Teleswitch Wiring Eco 7 in the UK Electrical Forum area at ElectriciansForums.net
H
highspark
Does anyone know off the top of their head how to wire a SangamoSchlumberger teleswitch for Eco 7. A diagram would be even better!
Rewiring domestic property where customer originally had storage heaters. The plan was to remove the storage heaters and install C/H. The customer has done a u-turn and now wants storage heaters back in on Eco 7.
Unfortunately I removed the tails from the Henley blocks and have no idea how to wire it back in. I know it's a long shot but any help would be appreciated.
Is it economy seven or convoy 10 I think, white meter rate where it boost t times of the day? If so I can probably he'd some light on that having just done one.
- - - Updated - - -
Just to add, mine was for storage heaters on three phase.
The whole teleswitch.
From left to right I'm presuming it's something like this....
Live in for storage heaters
Live in for antenna control
neutral in for antenna control
Switch Neutral for coil in dual meter
live out to DB
E7 Teleswitch
First terminal on the left is Permanent live in (fed from the outgoing side off the meter via a splitter/ Henley block ) , second and third is the live and neutral power supply for the teleswitch in that order( Live is via a slidelock fuse) next is the switch wire back to the E7 dual rate meter ie the switch wire , and finally on the right hand side is the outgoing off peak supply .
E7 Teleswitch
This is pretty much how I had pictured it. However on the last install there was definitely not a slide lock fuse. It was just fed from the live Henley block
Reply to Teleswitch Wiring Eco 7 in the UK Electrical Forum area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I have a client on a Superdeal tariff from SSE, the Superdeal Meter has 3 sets of tails coming out of it feeding 3 DBs: (i) DB1 - the main board...
Hi all looking for a bit of advice. I've been asked to price a rewire for a early 70's build 2 bed apartment. The apartment block was built in the...
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
