Discuss Testing ballasts/chokes in the DIY Electrical Advice area at ElectriciansForums.net
Carolina
Evening. Got my hands on a pair of choke ballasts to run fluorescent tubes a few days ago and I want to see if they're in good condition.
If we're talking age these things are relics, manufactured in the USSR in 1964 and 1971 respectively, the guy who gave them to me said they were working around... 10 years ago. I also got the fittings which I'm restoring and rewiring, each takes a single 40 watt tube.
I've measured R using a multimeter and compared against a known working ballast, The DC R of the working one is 72.5Ω, but the R of the older ones is 22Ω and 31.7Ω which seems odd, at least to me. I don't have an inductance meter.
From size I know they're meant for either 40 or 60 watt tubes (T12s) but I don't want to risk ruining one of those during the testing. Would testing in series with incandescent bulbs work?
P.S I won't be switching to LED 😛
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project to keep you out of the pub for a few nights.... Link
Reply to Testing ballasts/chokes in the DIY Electrical Advice area at ElectriciansForums.net
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
Hi: I am the custodian at Peru Public Library, Peru IL. About 20 years ago, I installed about 150 new General Electric brand electronic ballasts...
Hello, I am new to this forum and not an electrician. I am an Electrical Engineer though. I have this kind of a ceiling lighting -...
I want to operate 3 lighting set up using metal halide lamps for studio works or cinematic projects in the future. as of now i have got two...
Hi all, I've been having some issues trying to fix a fluorescent light in the bathroom. Here's the steps I've taken so far after it suddenly...
