Discuss Testing floods with P.I.R's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
revolt3k
When testing IR on a circuit spplying some outside floods with built in pir's, Is there any other way other than disconnecting the p.i.r in the fitting's?
yeah i can isolate via a 20A isolator but i need to test the circuit feeding the lights. Not to worry i will have to disconnect the light fittings and place a connector on them or just disconnect the feed to the fitting in the terminal block in the fittings themselves for the IR test. Just wondered if there was another way. Might need to do this on my assessment thats all.
thanks
Reply to Testing floods with P.I.R's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I am never quite sure if I am doing too little or too much when someone has a flood and I am called in. The most recent example is a chap has had...
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Did a couple of inspections on 2 x 2 bed ground floor flood damaged flats today, only 4 circuits in each, bizarrely one socket circuit and 2...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
