What prompts this statement?, please explainThe Ring is dead, long live the Radial!
When wiring socket outlets do you:
1. Use ring final circuits
2. Use radial circuits
It can't be an either/or question. There are questions of suitability....certainly in my opinion. Are Click are bringing out a 'radial only' range?
Just thought it would be interesting to see what is being used most!What prompts this statement?, please explain
No planning. Just looking at what you all think. There is no wrong answer!CLICK must be planning / looking at something that would make radials possible without having to use a 50 way D.B
My Son has just bought a 4 bedroom house in the U.S.A, it's got 3 D.B with a total of 58 circuits in them.
All sockets are on radials
This is a very valid answer! Just a post to see what the majority say. Interesting to see if people do pick one of the other or whether they'd agree with your statement of it not being an either or question.It can't be an either/or question. There are questions of suitability....certainly in my opinion. Are Click bringing out a 'radial only' range?
'Prefer' rather than 'use', perhaps?.....but it's still suitability.
So why not ask that question rather than stateJust thought it would be interesting to see what is being used most!![]()
As has already been mentioned both types of circuit have there merits depending on the particular requirements of the customer and the premisesThe Ring is dead, long live the Radial!![]()
Fair enough. Problem with your question is that both are used. It may be a preference or it may be designated.Just thought it would be interesting to see what is being used most!![]()
Both is a perfectly valid answer tooFair enough. Problem with your question is that both are used. It may be a preference or it may be designated.
I've no doubt, though, you'll succeed in getting a fair bit of attention with your 'question'.......especially if the 'anti ring brigade' catch on.
But not a voting option!!!!!Both is a perfectly valid answer too![]()
Nearly all would say both, then. Only dipsticks wouldn't....Both is a perfectly valid answer too![]()
Then most domestic's wouldn't understand what you're tawkin abaat...???? until they get to 'gut feelings'I think a more searching question would be:
'Apart from selecting ring or radial socket-outlet circuits on their merits for the requirements of a particular installation, do you have a personal preference or dislike for one or the other on the basis of conceptual limitations, suspicions or gut feelings?'
It's not in my opinion, a standard circuit as far as BS7671 is concerned at least I don't think so.Where is option 3 - Lollypop?
Hindsight us a wonderful invention Mate don't fret over it.Maybe I should have put an “ironic” emoji on my post. I know it’s not a standard circuit
Could,nt you have a problem with grouping if many 2.5mm t and e leaving the cu if all radials?Number of sockets to install is also a factor. 1 point on a ring is a bit pointless....
“Ironic” emoji
Well if you are talking BIG sockets and have to double up conductors for current carrying capacity...Number of sockets to install is also a factor. 1 point on a ring is a bit pointless....
What about option 4 - Hedgehog. RFC with loads of spurs?Where is option 3 - Lollypop?
A coronavirus, a 6mm ring with lots of 6mm radials with 2.5 rings on the end.What about option 4 - Hedgehog. RFC with loads of spurs?![]()
That's just an RFC with multiple spurs, mothing odd about that methodWhat about option 4 - Hedgehog. RFC with loads of spurs?![]()
I know PeteThat's just an RFC with multiple spurs, mothing odd about that method
If you mustI know PeteCan we call you Pete999 aka Lord of the Rings?
and no doubt a proliferation of fire nuts. on another forum, predominantly American, several members praise their silly wire nuts and condemn wagos.People think rings are bad , I recently watched a video of a guy wiring his house in America and he put lights and sockets on the same circuit using the same sized cable and kept calling it ‘roughing’ in his wiring...
it was blooming rough and at every point he stripped the cores back & twisted the bare copper earths together and shoved them in the back of each box so he had just the L & N to connect later
