Discuss Trips the current. in the UK Electrical Forum area at ElectriciansForums.net
johnpaul
I have two 1200w Mini Cookers which trips the current. If I use a 2500w kettle, it is OK. If I use a 2000w fan heater it is OK. I cannot see any faults with the cookers and cannot get my head round what is happening. Any help appreciated?
Most likely issue is a fault with each of the cookers.
The rcd is doing its job correctly by turning the power off when it detects a fault.
if the mini cookers have been out of use for a while, there could be damp in the elements. one way to dry them out is to plug into a socket that doesn't have RCD protection and run them for a while.
An RCD doesn’t give overload protection, so adding up the wattage doesn’t give any clues.
it may be a faulty element, or faulty connection within either appliance.
Do the work ok separately?
Is it one rcd for a number of circuits? (Cumulative?)
Fault with the element would be my guess. A PAT test (yes yes I know) would reveal the fault.
RCD trips due to current in L and N not being equal (leaking to earth). Of the appliance however tests fine then you're looking at something else but my money is the appliances, elements specifically.
Thought I posted this last night ?
Reply to Trips the current. in the UK Electrical Forum area at ElectriciansForums.net
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP! Every so often (twice in the last two days) when running the hot...
UK Strange
I am decorating our bedroom which only has 1 double socket in it. We have been using multiple gang sockets which are untidy and a trip risk, so I...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
