Discuss troubleshooting digital door entry system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
R
rumandcoke
hi forum,
i am new to this site and this is my first question
i am seeking advice on troubleshooting problems on a ISM C2000 digital door entry system
are they any members, who have worked on this system or similar, who can offer any practical information or troubleshooting tips
having read the manual, unfortunately, all they provide are troubleshooting tips for a new installation
currently the system has a zone fault, where:
- all magnetic locks for that zone are de-energised
- all handsets for that zone do not function
thank for reading, any assistance is appreciated
On a first impression I would say that the power to that zone has failed, either from a loose connection, failure of a local power supply or incorrect connection of power supply.
I do not know about that specific system but if you have a wiring diagram it should be easy to check for voltage at various points along that zone and see where it stops.
hi
the door entry system is a mix and match of ISM and PAC equipment
both ISM and PAC equipment are used for fob readers and decoders
PAC equipment is used for master and slave door controllers
the problem to the handsets was traced to a faulty ISM door control panel, fortunately a spare was available
the problem of the doors in fail safe mode was traced to a faulty PAC 2200 series controller
all inputs to the controller are ok, eg cabling, connections, power etc
but the unit fails to provide the 12v output to the door magnets
the unit is now obsolete
any pointers on how to get 12v output to the doors, how to repair this unit or source a replacement would be helpful
Reply to troubleshooting digital door entry system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Hello, I am looking for a door entry system with fobs to operate a mag lock on a door. Ideally I would have a system which records of log of what...
Hi We're a block of flats about to purchase some new external doors, and an intercom. Up to this point in time we've not had an intercom, and our...
Hi everyone We have a little problem with a heating system on one of the projects (quite big house in south Kensington) and we are looking for...
Hello I’ve recently had to rewire my home alarm system as the engineer who installed it did such a shoddy job that all the cables were hardly in...
