Discuss TT Earth cable sizing in the Australia area at ElectriciansForums.net
C
chloebear
Hi al,
Just need a bit of a refresh regarding the sizing of the earth cable for a domestic installation with an earth spike. I believe 10mm for the gas & water bonding, but seem to recall that the main earth cable can also be 10mm?
On a TT system the earth cable to the spike can be 6mm, but I always fit 10mm as it makes sense when your equipotential bonding is 10mm
As others have said, it doesn't have to be 10mm, and can be 6mm, but as I usually carry 10mm for main bonding anyway, I usually use this, as it saves having to stock/carry another roll/size of cable
I would size it according to pme supplies, not that it needs it at present.
Two reasons
1/ Possible upgrade at a future date to pme
2/ Mechanical protection of the the earthing conductor and from corrosion.
TT main earth 2.5mm² minimum, if mechanicaly protected, 4mm² if not (Reg. No. 543.1.1).
If buried, 16mm² sheathed, 25mm² unsheathed (table 54.1).
Bonding 6mm² minimum (Reg. No. 544.1.1).
Originally Posted by Sickmick
Main bonding hasn't got to be 10mm on a TT system.
Can you point this out in the regs please as my copy seems to have omitted this!!!
For a TT system you can have a 2.5mm main protective conductor if you so wish and the way to size is is done via reg 543.1.3.
Not really sure what you are getting at Malcom ???
Ahhhhhhhhhhhhhhhhhhhhhhhhh Trip to spec savers for me
Sickmick I do apologize I missed the 't from you post, but it is an age thing
And spark 68 thanks for pointing that out, before I crashed into a heap.
:leaving:
so that's me leaving
couple of large shots of JD might help, malc.
Reply to TT Earth cable sizing in the Australia area at ElectriciansForums.net
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi I have a domestic installation to rewire and the main incoming fuse is 80 amp so i am using 16mm double insulated tails, is the main earth size...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
