- Reaction score
- 10,215
I personally wouldn't run the load through timers, I would always use a heavier rated contactor to do the switching, this limits costs when elements fail etc as mentioned in my previous post and also heavier rated contactors have a higher chance of handling a fault current without consequence, it is up to you at the end of the day but unless you have different time requirements for the storage heaters then you only need 1 timer otherwise your just creating more work having to program 2 up the same.
