Discuss Two way switching plus intermediate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Greetings.
I am pulling cables through a conduit system next door and have a question. The lights will be two way plus intermediate. I have attached a link to a diagram:
View attachment WiringDiagrams (1).pdf
The diagram picture number 3 shows "two wire switching plus intermediate two wire control", this would really help me.
It would be just right with the amount of space I have in my conduit.
However I wired a switch this way at college once and my lecturer said it was rubbish, no one would accept it and I must do it again wired as picture number 5 "two wire switching plus intermediate three wire control."
Is it OK to wire like picture 3 "Two-way switching plus intermediate 2 wire control" or is this a big No No.
I mean I can't see why not, if I haveto wire it as "three wire control" I would haveto terminate everything in the switch and really stuff the conduit with wires.
Comments would be appreciated.
Thanks.
the 2 wire method is absolutely fine mate, and i have wired a whole boiler in a power station that way.
The 3 wire method is better for domestic situations where you have no containment.
well for the 2 wore method to work, it will probably require a single switch wire from the switch, to the fitting. This will not be able to bhe incorporated into a cable unless you have spare cores.
Conduit, trunking etc
Well I have plenty of conduit.
I was thinking of using this job for my assessment, maybe the assessor will hate it.
There will be no spare cores, it is all wired in singles.
The three wire control must be for when we use T and E cable not singles.
I mean I was taught at work to wire everything to the switch and terminate all the neutrals there but with singles you can terminate the neutrals anywhere.
What about junction boxes? They are OK to terminate into so taking this idea further it must be OK to terminate neutrals into connector blocks anywhere that is convenient so long as you don't cross neutrals, the same can also be said for CPC's, so long as the CPC is continuous why not make all your neutral and CPC terminations inside a light fitting for instance if that is the easiest place to do it or am I barking up the wrong tree?
As regards safety it is safer to not stuff conduit with additional and unnecessary wiring when you can slim the whole job down to half the wires.
I mean surely the golden rules are don't cross neutrals and maintain CPC continuity and that's it, the rest is up to me.
Both methods of wiring are fine. If it is easier for you to wire the switching in 2-wire then there is no problem with this.
I quite like 2-wire switching but it is not always sensible to do depending on the physical layout.
Terminating in light fittings is standard and much better than using another junction box, so long as the connectors are appropriately enclosed by the fitting.
Get the electrical regs bit right and you are OK, the way you get it right does not matter.
Reply to Two way switching plus intermediate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Hi, I'm currently in my year of my apprenticeship looking for some help with the 2 plate method (feeding the switch). I understand it up to the...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
