Discuss Vaillant combi store cylinder stat problem in the Central Heating Systems area at ElectriciansForums.net
Could get continuity across spade bits on back but not on terminals on front, with stat turned up or down across either nc or no terminals
Are you sure there is no integrated high limit reset in that stat? As you should obviously have continuity between screw terminals and spades.
I've never worked on one of these before but that looks like a reset button in the middle of the big shiny nut!
Are you sure you are experienced enough to be able to work on these? unvented cylinders can be pretty dangerous things if you were to do something silly like bypass a safety stat and let them get too hot! And of course they do have their own rules and regulations surrounding them.
1. Yeah I was wondering if that was a re-set when I relooked at pic
2. If it is I find it strange if it needs re-setting when it is a brand new part
3. Don't worry I won't be bypassing the stat, I just did it to check I wasn't going (totally) mad and see the system would run
4. Yes reasonable amount of experience cheers but not afraid to look silly if I'm wrong, hence the post on here, by no means a heating system specialist though
5. If that is a re-set button and I've been on the phone to vaillant technical and they haven't mentioned to try it...oh never mind
I don't touch heating, pipes, stats, trvs, anything that involves plumbing or central heating, ts a plumbers job, not mine, I don't have a clew what I'm doing. I'll be open and honest, I have no experience of heating controls.
So you are posting here just to boost your post count then?
If you are an electrician then wiring heating systems is part of your job.
Unfortunately there are far too many people working in the domestic sector and calling themselves electricians that just can't wire boilers, it's ridiculous.
And then there's the ones who think they can but get it completely wrong when faced with 2 heating zones!
It's not the plumbers job to wire and connect the controls, it is yours. What would you do on a new house that you were wiring if plumber said Im installing upstairs and downstairs heating zones and an unvented cylinder (S Plan +), would you sub it out?
Reply to Vaillant combi store cylinder stat problem in the Central Heating Systems area at ElectriciansForums.net
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
