Discuss Volt reading across N and cpc in the UK Electrical Forum area at ElectriciansForums.net
I'm in a vineyard. There is a 300m buried SWA from the ccu direct to a 2 gang socket.
I'm getting 247V across N and L at the ccu.... But at the socket I'm getting 100V across E and N and 147 across L and N.
Continuity as a radial tested ok
IR All over 500 M
Please list possible issues here. Thank you.
Are there any loads attached at the time of measuring?
What were the continuity results and how did you measure them?
300m is a long way, for what I presume if connecting directly into a socket, is going to be <= 2.5mm SWA.
IR All over 500 M
What size SWA?
How did you check end-to-end continuity? Is the SWA two core or three core?
First thought is a broken neutral or SWA/CPC somewhere along the length of the cable so am surprised your radial continuity checks are ok.
It's 6mm SWA
WAS GETTING 2 ohm continuity r1+r2
Measured with L and N cables removed from socket.
As above, if you put any load above a few Amps on that length and size of of cable you're going to get an unacceptably high N-E voltage....
Could you explain that a little please Marvo? I understand why approx 4A is the most you should draw due to VD, but how would increasing the load cause there to be voltage between N-E?
In a TN system the potential difference at source should be 0v in an ideal world. A circuit designed to have no volt drop should register 0v between the conductors at its point of utilisation. Once you start getting volt drop you must remember in normal circumstances there is no drop in the cpc but there is in the neutral and this drop will measure a potential difference between the conductors, the higher the drop the higher the pd between neutral and earth.
Reply to Volt reading across N and cpc in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Just interested in peoples thinking on using the neutral through the earthing system like I came across today. I've come across many wrong...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Looking for some guidance here. I'm currently shadowing a guy and we're testing a new extension on a school. 3 phase TNCS supply from the original...
