Discuss what is the best thing to do here in the UK Electrical Forum area at ElectriciansForums.net
Inline splice connectors are perfect for the job and ok with solid and you dont have to get a crimp tool in a confined space, downfall is slightly bulkier than a butt crimp but peace of mind is a good thing me thinks,,,,,,,,, and agree @GLENNSPARK one life too much ...well unless it was a bodgit and scarper who copped it from his own shoddy work then i can rest easy with that thought.
Some crimps the manufacturer's state that they are suitable for solid conductors, other's don't state anything.
Obviously if the manufacturer's state that they are suitable for solid conductors, you're good to go.
Ive yet to find one spinlondon that allows you to use them with the existing ratchet crimper you have in your tool kit, and to be honest ive rung around a few in the past and ive yet to find one designed for solid that has its own crimping tool!
Like i said before with the rise in popularity of push-fit MF connectors this debate will be soon a distant memory with the likes of the tap and turn drilling tool.
still don't trust 'em. they said the titanic was unsinkable and that was to BS.
I always thought that crimping solid core was more reliable than crimping multi...
Decent crimping tool and you'll deform the core so the crimp won't come off...
Personally I crimp both and do a tug test. Had failures occasionally with both solid and multi, but usually fine.
Soldered joint ... can't beat a PROPER soldered joint. ;)
Reply to what is the best thing to do here in the UK Electrical Forum area at ElectriciansForums.net
Not sure what to do here. I am wiring detectors for someone, boiler is in a small cupboard in the bathroom. Too small to fit the detector as it...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
