Discuss What is the name of the plug I need? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I lost the 3 pin plug for some LED fairy lights when we moved house and I’m having a hard time trying to find a replacement that the lights can fit into. I can’t upload a picture but I found something similar here:
I simply want a uk standard 3 pin plug that has a hole that the lights can plug into. What is the name of that sort of plug?
Thanks.
Jas.
Oh, I can now attach a picture. This is what it looks like.
I think the word you are looking for is "transformer"!
It just happens the transformer plugs directly into a socket.
From the label, 24V output and rated at 2.4VA (or more).
And obviously with the correct size of output connector (note: there are many variants of different sizes, some only slightly different but mechanically incompatible).
Thanks SJD!
Reply to What is the name of the plug I need? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi Guys. Is it safe to use an extension lead with a single pin 48V battery charger for an e-trike? The charger has a standard UK 3-pin mains plug...
Hello, I’m boarding out my loft for storage and I’d like some decent lighting up there rather than loft lights I’m currently using. I purchased...
4K
i have two molded rounded plug(type D) for Fan and Refrigerator but plug cable is not rounded that i cut before and replace with UK plug. those...
