Discuss What wall mounted electric heaters to use for an apartment these days ? in the UK Electrical Forum area at ElectriciansForums.net
Seem only to be good for "local" heating and instantly go cold when turned off . Rointe as mentioned do get a lot of attention. Budget will be around £400 each and we need 4Herschel infrared would get my vote
cheers .Lifestyle range from ATC.
Local timer, open window sensor etc. Oil filled. Look the part as well.
thats exactly the same as rointe.We went through a stage of re-fitting some pharmacies a while ago and I'm sure it was the ATC range we fitted in the office, the box had a template for the heater screw holes on it and two little oval brackets with three screw holes in them you fastened to the wall and hung it off it.
without a doubt it had the most complicated timer on it I've ever seen. They were fitted to supposedly save money but I'll bet every one of them is now on constant because you need a degree in physics just to program the on and off times.
Reply to What wall mounted electric heaters to use for an apartment these days ? in the UK Electrical Forum area at ElectriciansForums.net
