Discuss Where should I run this cable too? in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
T
TPES
The job I am currently working on sky have come to install there cable.
They have ran through the building a shotgun style cable with a coax and phone (looks like 2pair for master) joined throughout the length then this cable to the office.
I need to get the office first fixed so it can be plastered and need to put the sky cable (s) in place.
Where should I run these into?
Should I split the 2 and run the to separate single galv boxes or keep the 2 together into 1 galv box?
the reason its a twin cable is because one co;ax is for sky ,and the other fro sky plus for recording,this cable neds to go from sky dish down to the sky box then a scart lead from sky box to your tv.
I would run one twin cable to a single galv box then terminate on a 2 gang plate.??
Reply to Where should I run this cable too? in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
Hi, I have bought a new house. It has coax cables running to pretty much all rooms. I would like to replace these with cat6, and install new face...
Hello I'm Ronald Alliy, I have current came up with what I believe is a Infinite Electricity source. Attached is my proof. I'm a noob at blender...
htps://we.tl/t-JHXw09romZ quick share to photo Hi there. I am trying to convert previous cable network cat5e installed when had non fibre in 2015...
