Discuss Which certificate??? in the UK Electrical Forum area at ElectriciansForums.net
Im adding a new RCBO and SWA from existing power bollard to new IP rated enclosure what certificate would you do? I think EIC but the bollard consists of 100amp main switch and 2x rcbos for sockets
Now on particular of instal at origin do I do the bollard? Or where the bollard is fed from eg panel?
Then distribution details I’m only adding power to a IP rated box?
Reply to Which certificate??? in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
