Search for tools and product advice,
Discuss Which plugs to use? in the Electrical Tools and Products area at ElectriciansForums.net
E
Earth Leakage
I'm seeking advice on suitable masonry plugs.
I'm currently using 5mm Hilti plugs, literally by the thousand, in a University student accommodation reno. for direct ceiling fix cable tray, ductwork, conduit, and surface mounting.
5mm seems the best to use, as it can be both drilled and pushed through whatever's being mounted.
But Hilti plugs are just so damned expensive.
Are there cheaper alternatives available that will hold as reliably and safely as Hilti. I've seen Plasplugs yellow plugs for less than a tenth of the price. So cheap, in fact, that I'm a bit suspect regarding thie long-term reliability. Fischer's S5 is the closest equivalent that I can see to the Hiltis, having a couple of "whiskers" to stop them turning in the hole, at about a quarter of the price.
What brands/types do you use, and why? Any advice from users would be greatly appreciated before make the mistake of importing ten thousand or so useless plugs!
I'm setting the plugs in reinforced slab floors and ceilings, and high-density concrete brick walls.
I have been using ordinary red plugs for years no problem,you only get trouble when you use wrong size bit or screw.red plug 5.5 bit with a 6-8 screw size never had one pull out yet.about 50p per hundred at toolstation,just avoid the rough ones as they are a bit brittle but the smooth ones are fine.in fact i think the plasplugs ones may be iffy,the ones that are ok come in a box and have a piece of plastic with 5 plugs either side,10 strips in a box.the ones with loads on a big strip(b&q) are terrible.
You can't go far wrong with standard Rawplugs, they have plenty of 'meat' on them and grip well when matched to the recommended screw and hole sizes. If you want a cheaper alternative the generic Screwfix version are OK, just not quite so 'meaty'. Avoid Tower wallplugs they are very thin and can be totally useless in soft materials or slightly oversize holes.
Reply to Which plugs to use? in the Electrical Tools and Products area at ElectriciansForums.net
After a bit of advice please, been doing some work for ladies of a WI group and they have asked me to look at the heating / electricity...
Hi there. I'm building a house and need some help with the LED lighting design. Lots of experience wiring things, some experience using LEDs (did...
Evening, Feeling really confused about fire rated downlighters. We need 26 for our extension which is part flat ceiling and part vaulted ceiling...
4K
Hi folks, This is my first post, I hope you're all well and surviving the lockdown. Long story short, I had an electrician who was going to do...
I've been doing a bit of research on the standard British 3-pin plug under BS1363 as I would like to know exactly what is/isn't compliant so I can...
10K
