Discuss Wire a double oven in the DIY Electrical Advice area at ElectriciansForums.net
Hi am replacing my double oven. And was wondering what wires go where in the connection on the oven see attached photos.
Much appreciated in advance for your help
What do the manufacturers instructions say?
So does it work? I'd be testing it before fitting it just in case.
If you know the make and model you should be able to Google and download the manufacturers installation instructions.
Bought new or second hand. If new it should have instructions.
If second hand whoever is giving the guarantee should supply the instructions.
i'm sure a member is close enough to you to connect that up, ensure circuit and connection cable are correctly sized... for a small fee, of course.
Reply to Wire a double oven in the DIY Electrical Advice area at ElectriciansForums.net
I have just replaced my old double oven which was about 10 years old with a new model as whenever I used the top oven it tripped the electrics...
Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how my oven is currently wired up, followed by 3...
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
