Discuss wire sizes - what is standard in the UK Electrical Forum area at ElectriciansForums.net
renault
hi all. I am new here and am doing some work on my house. I have a question regarding wire sizes; As far as I was aware the sizes are 1.5, 2.5 then 6.0 etc (I am assuming this is the area of copper) however I have just come across 4mm. dia. in my house. Is this an old standard no longer used ?
4mm is less common than 6mm as it is only rated for a typical 32A circuit in certain installation "methods" such as clipped directly to a wall where it can get rid of heat sufficiently easily. The other common 32A circuit in the UK is the Ring Final Circut used for 13A sockets, typically it is in 2.5mm as every socket in a RFC has two paths for the current to flow so typically the loads result in roughly half on each 'leg' back to the consumer unit (fuse box).
Of course, sometimes you also have to increase conductor size to keep voltage drop down on long runs (and related to that, keep fault impedance down so it clears quickly).
Tables 7.1 (i) through to (iii) in the IET's On-Site Guide(pages 65-75) are your go-to reference for wire choice. That covers the length limits and installation methods for the majority of common circuits (combinations of cable size and over-current protection device).
I haven't fitted any supp bonding since we have had to rcd the carp out of everything
I now only carry 1mm for lights , 2.5 for power and 6 for cookers
I do have some drums of 1.5 and 4mm in my garage but rarely use that size cable
I must have a bigger van.
I carry 2 x 1mm, 1.5 and 2.5… a 4,6 and 10mm T&E . 1mm and 1.5 3c&e
There’s normally a drum of coax rolling about, plus cat5, bell wire and telephone wire at home.
Then the 1.5 and 2.5 singles…. (All colours of 1.5). And 4 and 10mm single earth wire.
Edit:
Plus numerous coils and cuttings of small size flex in 3183, 3093 and rubber. 3,4 and 5 core in some sizes…. 4mm flex for ovens, half drums of SWA and some 25/16mm tails kits.
diameter of cable/s is irrelevant. except when choosing thre rightsizeof clip/cleat to fix it. all that matters, elecrically, is the csa. area of conductorr in millipedes or fraction thereof.
They are sort of "in-between" sizes. No need for 1.5mm for practically any lighting circuit as current small (and harder to wrangle it to light's terminals), but then not quite high enough for many fixed loads.
4mm is sort of the same in-between size. You often hear folk suggesting a radial in 4mm but in many install methods that is not 32A-safe.
Reply to wire sizes - what is standard in the UK Electrical Forum area at ElectriciansForums.net
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
