Discuss Wiring lights in flat with concrete ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
allybally
Started A job today, concrete ceilings, and was thinking of ways to get the cables from switch to pendant, and thought of chasing the plaster and artex of the ceilings, and glue gunning the cables up and bonding/plastering over, do you think this is do-able? Don't really want to trunk it, thanks
the absolute best way would be to fit 2 x 2 battens to the ceiling, then board it after the cables are in.
Are you going to deal with the asbestos in the artex before or after you chased the ceilings?
it was until around 1985. then they took it out and then the artex was pants.
What is the site like?
A posh house, where a chase across the ceiling would look like a bag of nails, or some South Yorkshire council flat where the occupants couldn't give a monkeys?
It's a crap flat in a nice area, but shallow ceilings, tried chasing into the concrete and went trough the ceiling, not great, so back to the drawing board
It's already been said, but...
Asbestos was prevalent in artex until approx 20 years ago. Get it professionally tested and removed if necessary. Then batten and board as per post #2. Don't disturb the artex in an way until you know what you're dealing with.
Edit: Actually, it may be 30 years.
i think the amount os asbestos in artex was very low risk.
Reply to Wiring lights in flat with concrete ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
