Y
yasser
Hi Guys, a little bit of help required. I'm trying to tidy some wiring in the loft above the kitchen. Whoever lived here years ago seemed to do all his wiring with red tape and connector blocks. For some reason (probably to get rid of all the little bits of wire) they have used 4 different pieces of 1.5mm twin and earth from the consumer unit to the boiler. There is a 6amp mcb on the CU and a 3amp fuse and the boiler and there is nothing else on the radial. The question is, I have half a reel of 1.0mm in the garage, can I replace these bits with one piece of 1.0mm or should it be 1.5mm. Thanks in advance for any replies
