Discuss Wylex Compatibility in the Electrical Tools and Products area at ElectriciansForums.net
I agree with @suffolkspark that doesn't look like Wylex. The cover door looks too big, the embossed ON/OFF and CE mark is not a Wylex thing and the cover screws are off centre.
Yea I suspect its a PEP board (premium electrical products) with a 100ma wylex slung upfront, which is kinda correct given its TT as I see a lot of metal dual rcd boards on TT with no 100mA upfront, but I bet its not time delay, and obviously it's wrong brand. @OP PEP do do rcbos so that's probably going to be your route if your keeping that enclosure and get a PEP main switch back in it, can only see them on ebay from a quick look though
Not sure if that would be permitted as it’s a wylex enclosure?
It’s very annoying how Wylex keep changing all the parts so they are not backwards compatible every 5 years or so. It’s mainly why I don’t use them!
Don't think that's a Wylex enclosure. It's a PEP enclosure. Ive only ever seen one once and that was on EICR a few week back.. Funny enough that had a few mixed mcbs too.
Hager dual and single RCBO's do fit a Wylex board and any busbar with a 13mm dual or single pitch will fit in a straight line.
Reply to Wylex Compatibility in the Electrical Tools and Products area at ElectriciansForums.net
I may well need to change all the MCB's for RCBO's in this board (see picture). Do Wylex RCBO's fit in this board? It is currently fitted with...
8K
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Doing a CU change yesterday, having purchased an 8 way Wylex board and 6 Wylex miniature RCBOs recently, and was about to fix the board until sods...
5K
