Discuss Fire Aarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi,
You can see why they didn't want to show their face in that video, it's a rubbish install; and they must have gone to a lot of trouble to get all the accessories at different heights.
Regards.
It`s a great video nasty.....as most pointed out, heights incorrect, wrong fused spur, no cable protection etc.....But the most disturbing, is the mounting of a detector direct onto a beam. Allowing smoke to fill the above ceiling space, before reaching the detector. This is the difference between early warning, and adding vital time to a system
So I asked them why it's been done the way it has and they've responded claiming it was the only possible way because of multiple beams. The different heights are so that no one can confuse a break glass and a light switch.
Some load of old guff like that anyway.
What a ridiculously response...
First class muppet
A little knowledge can be dangerous......I find it hard to explain sometimes on here, as every situation can have different standards, prime ones are flats above shops. They become part 6 mixed with part 1 ....high raised flats above 20m ...members ask why no fire alarm......why is 75db not required in hmo when part 6 says it should....risk assessments and building control all have logical reasons, and it takes a lot a years to get to grips with the logic
Ive just posted to it ... Tazz might correct me here but said BG is sited incorrectly as its likely to be pressed trying to turn light on, as the panel is close to door I said a B/G under the panel would have been more suitable... im genome616 btw.
Hold on Ill check my privacy settings on there....
Nope all ok there says posted 15mins ago... have you refreshed the page?
We have to cover exit routes so common sense comes in all these situations.....if there is a possibility of pressing the call point instead of a light switch...then a lift up perspex cover should be fitted....this is very commonly used in schools, colleges and commercial premises. The idea here...if you lift the perspex cover, then the only reason would be to activate the fire alarm.
Down to a risk assessment again....a mcp with cover maybe requested to have break ties fitted.....this is used to prove and document a call point has been activated....just another method of false alarm prevention
Fitted these covers in a office exit as no real alternative siting ....was just curious as to sticking that BG under the panel in the vid as its still next to the door and nothing in my recollection says you can't, still easily accessible and not looking crap but up to a light switch.
Pretty sure would another be a cover which has encased the whole MCP and when fascia of case is opened sets a small high pitch alarm to alert others for false alarms or preventing of false alarms...
Felix Moran just said "Please, in the future put as much effort into finding excuses for not making dangerous videos as you do excusing your shoddy wiring"
Wonder if that one will be allowed.
Sensible question....if close enough to the exit...or within the exit route...then yes...but the idea is would a person exiting the building use the mcp...a design must ensure this is an option. Being placed on a door exit would expect this
Think I will start doing videos on the real install.....starting with cad design...then sitting around the consulting table in meetings....the install on site and the then commissioning and handover.....could be an epic...lol
If there was some sort of commentary explaining what was being done and why I'd say fair enough but all that's being done is some cables appear through some holes and the seem to terminate themselves. Any bloody idiot can do a video like that.
Chris Kitchener manages to explain things fairly well in his "how to" testing films so why can't this muppet?
I think we made a point....as original video has now been removed.
Hes's more likely blocked us all lol... in my You Tube history it now say's 'Sorry this is video is private' so it may be still about or temp' locked out of view.
Reply to Fire Aarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
This weekend at Electrical2Go we are offering the Ansell Prism pro (APRIP/1) for just £6.95 ex VAT ! These are one of our best-selling...
My FIL wants a cctv system at his house, and normally i would just go with whatever kit was on offer at the time from t'internet. My own system...
