C
Christoph66
Good evening all,
was told that the trainee area would be a good area for me to go in and I've messaged Admin a couple of days back but haven't heard anything back yet.
Just wondered if anyone else would be able to help on this
And also If I could post a little bit I got stuck on in my work (again) lol :
Identify the tests that would be carried out to locate each of the following faults, as reported by the client.
a) A circuit breaker keeps tripping, as soon as it is reset, which is protecting a socket-outlet circuit.
b) RCD on the outside lighting circuit trips frequently, even though the outside lights are not in operation.
c) Main protective bonding conductor is damaged near to the ’Stopcock’. The conductor is partly concealed in the fabric of the building.
For a) Got a bit stuck on- you can't do RCD test on a) can you as is not RCD ... (apologies if this is a stupid question) would I need to do any test from the socket oulet?
for b) am I right in thinking An RCD test could be performed to test if the RCD is too sensitive?
and c) would be continuity of main protective bonding test wouldn't it ..
Any help would be appreciated , sorry for the long post guys.
Many thanks
C
you got c) right.
a). short circuit on fixed wiring or a short circuit appliance if plugged in.
b) as the lights are not switched on, (L supply off), there must be a N-E fault. probably wet in a fitting or JB.
you got c) right.
I suppose one is better than none! aha
Thank you very much for your help :) much appreciated.
a would require a low ohms continuity test between live conductors at various points on the circuit breaking it down as required to narrow down the location of the fault which would be a fault of negligible impedance between line and neutral (or possibly line and earth but as it is a socket circuit it is likely to have 30mA RCD protection in which case the RCD would have gone first)
b would require insulation resistance tests between neutral and earth with the conductors disconnected from the board breaking down the circuit again to identify where the neutral earth fault is located.
c would be a low ohms continuity test using the wander lead method R2 to assess whether the bonding conductor had been damaged sufficiently to increase the resistance of the conductor and so require repair.
Thank you very much , appreciate it.
Hi Christopher,
To apply for access to the trainee forum start a new thread here.
Copy and paste this and fill in the blanks.
Your Details
Your Full Name:
Your Address:
Your Telephone Number:
Training Details
Training Providers Name:
Training Providers Address:
Course Details
Course(s) you are taking with the Provider:
Date the Courses/Training Started:
Date the Courses/Training Should Be Completed:
Qualification(s) Gained Once Completed:
Nobody except forum staff can see what's been posted by you when you apply for trainee forum access. We don't pass on your private info to anyone else, we only use it to verify you're a bona fide trainee.
Hi Christopher,
Your Details
Your Full Name:
Your Address:
Training Details
Course Details
Thanks, done. :)
Reactions: Pete999
Hi Christopher,
Your Details
Your Full Name:
Your Address:
Training Details
Course Details
Hi,
I have done as requested but still haven't heard anything? any ideas?
Kind regards
C
Could depend on how many people applying & how long it takes to verify your details.
They will let you know when they're done with the checks.
Plenty of stuff to read through on the forum in the meantime and then if you have any questions please feel free to ask.
Just remember, the only dumb question is the one you don't ask. ;):)
Reactions: Christoph66
There is indeed! And thanks, will do, much appreciated. Haha, True. :grin::thumbsup:
Actually Specialist we do get some actual dumb questions sometimes!
we have a dumb button for them. (as well as some sarcastic comments).
Yes mate Know, but I meant from the OP's perspective as a Trainee. Have to be fair, they're not the ones that usually ask the dumbest questions :)
I'm only ever positive with my button usage - I always feel that it'll go down on the report card for the end of the year.
Now if I think it's not quite intelligent - I'll just say it with words.!
Simples!
Christoph66,
Christoph66,
