Discuss Photo's of Work carried out today in the UK Electrical Forum area at ElectriciansForums.net
KennyKen
150mm Duel Feeders for HVAC Panel.
Junction Box is Ex 'E' so limitations on core length..
That was part of my work tonight.
Yeah the SWA's here have an Earth inside instead of running a separate Earth externally. The Enclosure has an Earth tag on the outside. So the Banjos are on outside but are Angled as you can't drill the enclosure. The enclosure has a specified amount of holes depending on which Zone it's mounted in.
Forgot the heating....This is the start of it. Seperate pumps and valves for, ground, 1st and second floors..Also seperate pumps and valves for Towel rail circuit and hot water. 300L cylinder and a system boiler. There will be two more pumps for hot water return and UFH. So 7 additional pumps to the one in the boiler itself. The UFH on the ground floor has 12 zones.
Posh b******d's, my house plot isn't that big, let alone my poxy garden. They've made a right mess of the front lawn, or have you been fly tipping Lee.
lol the electrical package is around 40K and that's without the AV and RAKO who someone else is doing. I would of thought they're around the 50K mark. The whole front is being dug up and redone. There's loads of coin in Surrey...This is the 3rd house I've done for the same family with another one in the pipeline...
who's the suspicious looking hoodie. a burglar?
I had a heating system years ago a bit like that Lee except only 4 pumps altogether. Had a bit of a head scratcher on how to fire the boiler and only certain pumps without introducing relays so in the end settled on wiring the pump feeds in with the brown on the corresponding Motorised valve, figured the valves wouldn't take long to open once actuated.
yeah didn't have to get out of the van for the EICR's as they looked alright from the roadside lol:eek:
No Lee your a proper Sparky, not one of those that can do EICR's & Fault finding telepathically :D.
I'm just waiting for someone to come on here & tell us something like that, Sparky gave them an EICR without a visit. :mad:
I think I may have been doing the remedial work from that 'sparky' yesterday.
Apparently there was no supplementary bonding in the property and one unknown circuit. Shaver sockets in the bathrooms that had them (the only electrical accessories present aside from the lights/fans) were properly bonded, he obviously just couldn't be bothered to bend down to look under the sinks and the mystery circuit ran to a single socket outlet about 4" away from the CU. Obviously 30 seconds identifying that wouldn't yield an hours labour for the investigation.
Deleted
I must admit, I've not bothered checking supplementary bonding recently - naughty boy - most of the pipe work for radiators is speed fit, and the hot & cold is hidden away behind bathroom furniture :eek: And when the place is visited by just a plumber, you wouldn't see him bothering to check. There, I've said it now.
Was the requirement for bonding ever tested?
Should have realised "Speedfit=Plastic" Doh
No but, you make a good point. I often check pipe work etc, before work starts to verify. But quite often when I go back, its all plastic, been altered and the floors been put down. If the pipe work can't be clamped elsewhere, some customers will get a bit annoyed having clamps and green/yellow cable everywhere. Just saying.
Reply to Photo's of Work carried out today in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am just wondering if there is anybody out there interested in allowing me to do a little voluntary work with your company to gain a little...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hi, go easy on me please, I've just returned to the trade, well I am about to, I received my Gold Card last Thursday. I've been gen'ing up for a...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
