Discuss What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i'd be more concerned about that floating open end red insulated conductor and that ropey looking blue crimp connector.
Also the neutral in terminal 10 looks as if the copper strands have been nicked when stripped....
Compared to the crimped connections, that connector on the earth doesn't look too bad in the photo!
and a yellow crimp behind the spare way.what else is hidden from view? this appears to have been a CU upgrade . if so, it was a job crying out for a din rail box cable extension, to avoid all these bodges. Electrical Trainee or Dave from the pub, done it for £150 + 2 pints?
Cables have been extended.
Red Blue and Yellow insulated crimps have been used on appropriate cables.
Terminal blocks on larger cables.
I guess whoever did the work didn’ fancy using solder or uninsulated crimps?
Hate unfixed block connectors proper unskilled work and those who approve how do you suggest anyone can check terminal tightness in this instance.
Back of the board has been knocked out leaving internal conductors exposed to a combustible surface.
I haven't seen someone cut the back of a board out before. I'd have thought it would've compromised the manufacturer's design in several non recoverable ways. Stuffed it, in short.
I must say I see many CUs around here installed on wooden battens and all cables coming in through the rear knockout. Usually Wylex or Crabtree. Seems to have been the standard way of doing it for a long time.
Indeed. It's particularly advantageous where you need to add cables later. If access is tight, making a new hole in the side/top/bottom of a CU can be a right pain.
Bit confused where does mounting it on battens come into it. The board in the picture clearly has the back knocked out, is mounted flat leaving conductors exposed to a combustible surface.
You can’t code it for being mounted on a wooden surface even with the back cut out IMO without evidence of a problem or even loose connections.
Bit like a plastic consumer unit which is combustible.
Check tightness of connections,tight and secure, no code.
I was replying generally to the idea of using rear knockouts. In the OP's picture it does look like the CU is mounted straight on a wooden surface, with the back knocked out. Not sure why I must say.
You can code it for being mounted on a wooden surface even with the back cut out IMO without evidence of a problem or even loose connections.
You mean can't code it?
pity there isn't a code for "it's an abortion but it works, dunnit?"
Reply to What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
So I know why it is done, where it is done and how it’s done, but I’m yet to see a scenario where there is shock danger in a typical bathroom in a...
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
