Discuss kva to amperage westernpower in the UK Electrical Forum area at ElectriciansForums.net
simple. 40kVA per phase. that's 1666.66666666666 A per phase. if the phases are balanced/nth308£$"^
I have a quick rough calc I always use and you just take your kva value for 3ph and divide by 0.73 this will give you approx 164amps per phase.
If its single phase then divide by 0.25 so 20kva SP is 80amps.
If you have the amps and want the kva then multiply by these values.
I get 173 assuming power factor is 1
120000 amps /400 volts x 1.73. = 173.4 amps per phase
Edit I’ve used 400 volts rather than 415 volts. :)
Reply to kva to amperage westernpower in the UK Electrical Forum area at ElectriciansForums.net
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Hello everyone! I have a question regarding the electricity supply and the maximum demand. One energy utility supplies an 18 kVA maximum...
I wanted to find out if there is a way to connect Multiple inverters in series for a higher voltage. My Idea was since the inverters are limited...
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Hi all, I’m getting confused as to what the DNO are going to be installing as there main supply and as you all may be aware they tend to be a...
4K
