Discuss kva to amperage westernpower in the UK Electrical Forum area at ElectriciansForums.net
Three Phase Current - Simple Calculation - http://myelectrical.com/notes/entryid/8/three-phase-power-simple-calculationsafternoonafternoon
what is 120kva 3phase head in amps ? or what is the calc
oops, an extra 6 went in. should have been 166.666667simple. 40kVA per phase. that's 1666.66666666666 A per phase. if the phases are balanced/nth308£$"^
wheres the 1.73 fromI get 173 assuming power factor is 1
120000 amps /400 volts x 1.73. = 173.4 amps per phase
Edit I’ve used 400 volts rather than 415 volts.
It's the square root of 3.wheres the 1.73 from
Reply to kva to amperage westernpower in the UK Electrical Forum area at ElectriciansForums.net
