Discuss Consumer unit upgraded - no earth continuity question? in the UK Electrical Forum area at ElectriciansForums.net
I would say that until said spark has conclusively identified the location of the fault, and corrective work has been undertaken, the job is not complete, and the bill is increasing......
This is the most common fault in houses
That would depend. Most people ask for a quote for a CU change. A lot of tosh is spouted about EICR's before a CU change. Well anyone who wants to do a free EICR in order to quote for a CU change they may not even get is welcome to.
I provide a quote clearly stating that full tests will be carried out prior to and during the job and any faults found will incur extra charges to be agreed with the client.
As far as I am aware, there is no statutory requirement in the Building Regulations to comply with BS7671.
Guidance in the form of the Approved Document is not a statutory requirement unless identified as such.
Cert after payment here, never had an issue, if it gets to court on the basis that I have not issued a certificate and on that basis payment is being withheld something has gone horribly wrong. I normally take payment prior to leaving the house by cash or card. Certification and notification follows, some of you are far too trusting! I never have my hair cut and asked the barber to send me an invoice!?
How many times on here have we had jobs been paid for and no certificate issued together with electrician never seen again.
What about Reg 632.1?You have been contracted to do work in compliance with BS7671.
You are stating that as if, now the spark has been paid he/she decided not to give a certificate for work done BUT if you think about it, you’ll find that a certificate was never going to be issued - that’s the type of tradesperson they are and shouldn’t reflect on what we are discussing.
Just an observation on past posts on the forum from the general public when we ask them regarding the certificate and they have paid the bill with no certificate forthcoming. There is nothing wrong with stage payments. Sorry but if the electrical installation certificate is not issued the contract is not fulfilled and BS7671 is not compiled with.
I am struggling to see the link between a contract and compliance to British Standard 7671? There is not and never will be a specific link between BS7671 and completion of a contract unless it was specifically a written part of the agreed contract between the two parties. To say that if a certificate is not issued a contract is not fulfilled is simply not legally correct. There may be a non compliance of BS7671 by not issuing a certificate but this may have no bearing whatsoever on the terms of a contract. In fact payment (valuable consideration) is a fundamental part of the law of contract for which a breach (non payment) may be subject of legal action per se. In a legal situation whether the certificate was issued prior to or immediately after payment I would suggest would be seen as a minor issue, non payment though would have more of a bearing in court.
Well, if it’s a condition of the contract, that the work complies with B7671, then failure to supply certification would mean the work does not comply with BS7671 and that particular condition has not been met.
When I was an apprentice I worked with a guy who would always just downgrade the MCB from a 32a to 20a if he ever uncovered a open ring on a board change, I don't think he really understood the danger he was leaving behind, I think alot of 'sparks' do this,
Another one ive seen is moving two lighting circuits to the same RCD on a duel board to disguise a borrowed neutral.
@ Murdoch,you are right.
He is supposed to check the installation before changing the board (ECR)
And also after installing the new board to issue EIC after doing all the tests.
So is he going to note down the broken cpc on the cert?
Isn't it his job to make good the installation?
To be honest, if hes gone to the hassle of identifying where the break is, sorted 2 radials @16 and is part of NIC then it should be good.
Perhaps email asking if he split the ring so you have it in writing whats been done.
What ever he did should be entered on the certificate, he should have been issued with when the actual work/fault rectification was finished, the job would be complete once a cert had been issued.
Supposed to check whether the existing equipment is fit for any additional load (not really applicable for a CU change), and that the installation earthing and bonding arrangements are adequate for whatever protective measures are to be used.
Disagree with this - sure there are sites which I will insist on doing an EICR first but 19 out of 20 I will not ................. so uncovering unforeseen issues is something that ALL installers need to be aware of and also forewarn customers that addition costs may be incurred .......
In the case of this I wouldn't be issuing the EIC until the problem is resolved.
If the client won't pay .......... then a strongly worded note on the cert will be included.
Theoretically your right Mate, but if you do remedial work, that you find needs doing during the initial inspection, and it costs you say £40:00 and when you tell your client, He/She would be well within their rights to say, "I never asked you to do that, so I'm not paying" It's a difficult situation, my approach would be to do a few quick IR tests to ensure correct opperation of the replacement CU (no unwanted tripping from circuits that may not have been protected by an RCD) and issue an EIC to that effect, that's what you have been asked to do, so thats what you certify, by all means, if during the replacemnt you have noticed things that are not compliant, add this information either on the EIC or by a Letter given along with the cert. It would be their choice rightly or wrongly.
This is why I include this:
"NB : If problems are detected during the fuseboard change additional work may be required. Such issues and associated costs will be discussed with you, prior to being implemented"
On all fuseboard change quotes / estimates. Never been questioned about this, never had a problem on the rare occasions that issues are identified.
Anybody who doesn't caveat such quotes is leaving themselves open - which is probably a lot of people
Seems a good approach.
Reply to Consumer unit upgraded - no earth continuity question? in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
5K
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
