Discuss Help working out resistance and supply current please. in the UK Electrical Forum area at ElectriciansForums.net
Jacko
hi,
I’m doing some revision and I can’t quite understand working out the resistance of a circuit or the supply current. Could some one please help and explain how it would be done please?
I have attached a photo of the network and the question.
Hi mate.
1. Work out the resistance. Look at the resistors in series and parallel.
2. What is the voltage?
We must assume, although it does not explicitly state, that they want the resistance 'seen by' the battery, i.e. across its terminals with the battery disconnected. This particular network is easy to simplify step by step, using only the formulae for resistors in series and in parallel.
There are some groups of resistors in series - calculate these first, i.e. replace each series group with a single resistor of equal resistance. Then note how those are connected together, and calculate a suitable resistor to replace them. Then note how that is connected to the last remaining resistor, and calculate.
Show your working and we'll correct you if you go wrong...
I will try and clarify my post above... I come across as a muppet..:tearsofjoy:
1. Total resistance? Look at the resistors. E.g.
1a. R1 & R2 are in series.
1b. R3, R4 & R5 are in series.
The answer for 1a is in parallel with the answer for 1b.
That just leaves R6 that needs adding to the equation.
2. What is the voltage of the circuit. Hard to work out the supply current when you only have the resistance..
first, add the 20 + 30 + 50 (series). call that R3
then the 40 + 60 (series). call that R2.
then you have R2 in parallel with R3. work that out.
then you have that result in series with the 10.
once you have the network resistance, you need the voltage to determine the current. I = V/R.
with those resistance values, you can do it in your head. i did.
XXXXII. what have the romans done for us.
If the diagram is drawn correctly then the supply voltage is 3VDC, ie. 2 single cells in series. Although I suspect the actual figure has been missed out when it was copied down.
Yes it is. You have 2 lots of 100R in parallel with each other, and then 10R in series with that. This gives the 60R total
Very neat writing as well. You need to sort that before filling any certs in!
The answers are correct. You might want to mark up the diagram with your R1,R2 & R3.
Are you saying the answer isn't 60 ohms @Vortigern ?
That's what I've worked it out as.
I use the one over method for parallel resistors and make it 60 ohm.
My question is make sure you check the voltage as it shows two batteries in that diagram, is it 2x6v for your 12v or should it be 2x12v ?
I see R1 and R2 as resistors in parallel so product over sum would be my method for working those out first then add the the series. But I was interested to see if the sum used by the example worked is as it should be with regard to the OP.
Sorry I now see R1 and R2 are in series, I am slow but sure.
I'm confused now.. :tearsofjoy::tearsofjoy: Doesn't take much...
OP's post:
R1 = 100 ohm
R2 = 100 ohm.
They are in parallel, which is 50 ohm. Then add the 10 ohm to it. = 60 ohm.
I am reading this right, aren't I??
Yep I can see my mistake, sorry if I caused confusion to OP! I have reported myself and will sit on the stairs for a while.
You do realise it's 1 minute for each year of your age...
I'd be there for a long time....
I am going by the red number in post #4 that you put up @Spoon so the two R are 40 and 60 in series added together 100 Ohm. To avoid confusion @telectrix post #5 has it clearly.
How dare you.... :tearsofjoy::tearsofjoy::tearsofjoy:
I have each resistor idented... Mine is more clear...
See what you have done OP..... Hope you are happy...... :sob::sob::sob:
In that diagram because we consider the conductors to be of zero resistance the voltage is only dropped over the resistor so the two locations referred to in the text are electrically equivalent.
In each case the voltage measured will be the voltage dropped over the resistor.
Because there is only one resistor the voltage drop will be the supply voltage.
For the circuit you have shown.
The battery is supplying 10V to the single resistance of 5Ω.
From this circuit we can say that the current in the circuit, which is the same at all points because there are no parallel sections, is V/R.
That is 10/5 = 2 A.
To calculate the voltage dropped over the resistor we can then say that V= I R which is 2 x 5=10 V.
However this is redundancy because we know that the full supply voltage is, by definition, dropped over the length of the circuit, the only point in the circuit where voltage will drop is the resistor, so the full supply voltage, 10 V, is dropped over the 5 Ω resistor.
Electrically points 1, 2 and 3 are all the same point and points 4, 5 and 6 are all the same point, therefore any measurement from one side of the resistor to the other will give the same reading.
Reply to Help working out resistance and supply current please. in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
Hi, can someone please advise on where if anywhere I may acquire an adapter to duct out this old Elica cooker hood. The hole is 150mm x 90mm and I...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
Hi all I have a professional coffe machine working at 220 V and it currently drain about 2,5 kW of power. I have made this simple and horrible...
Hi Everyone, My first post here, just a simple question. I currently get all of my work through word of mouth and contracts that I have...
