- Reaction score
- 1
fitted dimmer switch but before lights were not working and still not working what do I do
Discuss Dimmer switch not working in the UK Electrical Forum area at ElectriciansForums.net
I just noticed I put domestic instead of traineeCall an electrician Kirsty
Serious question, have you tried a working bulb?fitted dimmer switch but before lights were not working and still not working what do I do
Hi KB and Welcome to the Forum!fitted dimmer switch but before lights were not working and still not working what do I do
I think that's the issue here as she says the 'other' dimmers are working it's probably a case of having 2 dimmers on the same circuitDo you have a standard switch to wire up, just to see if the light works?
Excellent, what was the problem so others in the future might learn?Problem solved everyone thank you
Reply to Dimmer switch not working in the UK Electrical Forum area at ElectriciansForums.net
