just want to upgrade old fuse box in home myself and get third party to test/certify ,possible?
Possible,but legally,the job should be certified by a third party inspector .,just want to upgrade old fuse box in home myself and get third party to test/certify ,possible?
Sorry,hadn't, read your post correctly.SPossible,but legally,the job should be certified by a third party inspector .,
Regards,S
OP has ONC Elec. Eng. and classes hin=mself as competent. according to BS 7671, that's sufficient for him to undertake the work. part pee compliance is another matter. don't get me started on the fact that a 5 week course guy who's joined niceic as a domestic installer ( not a qualified spark) can do this work legally, whereas a qualified spark of 40 years experience on top of "proper" qualifications is barred dfrom doing it.Honest advice
NO
there are a lot of other parameters to take into account, and until it is inspected you and your family are at risk
pay a professional to do it, and rectify any other faults found at the same time
that will be about 1/10th of a CO-OP funeral
aha I didnt see thatOP has ONC Elec. Eng. and classes hin=mself as competent. according to BS 7671, that's sufficient for him to undertake the work. part pee compliance is another matter. don't get me started on the fact that a Electrical Trainee who's joined niceic as a domestic installer ( not a qualified spark) can do this work legally, whereas a qualified spark of 40 years experience on top of "proper" qualifications is barred dfrom doing it.
Yes, but you'll need to get in touch with your 3rd party certifier before starting work. Some NAPIT and STROMA members will be 3rd party certifiers, but not NICEIC or ELECSA members.just want to upgrade old fuse box in home myself and get third party to test/certify ,possible?
Hi, I know that whoever takes the job on is going to have a hard time pulling the cables out of the back of old fusebox as some monkey back in 78 "stapled" twin and earths to plasterboard woodwork, as seen with snakescope! In view of what you said I shall just free up the cables thru light switch back box opposite, never seen such meaty staples!That would be up to the person you get to test and notify the job for you.
You should have them in first to assess the job and probably be involved in the design elements.
They would have to be willing to do such a task. Many won't be.
They would have to be registered with a third party notification scheme. Many aren't.
They would have to assess your competence and be satisfied with the standard of work.
Any reason you want to do this apart from the perceived notion of saving a few quid ?
we used to use a section of twin and earth as a clip and nail it in, either that or those old thin metal P clips, whack a nail in then fold its over the cable and through the buckleHi, I know that whoever takes the job on is going to have a hard time pulling the cables out of the back of old fusebox as some monkey back in 78 "stapled" twin and earths to plasterboard woodwork, as seen with snakescope! In view of what you said I shall just free up the cables thru light switch back box opposite, never seen such meaty staples!
i got a box of them in the van. you can still buy them, well, similar.these have some d/s tape on the back.we used to use a section of twin and earth as a clip and nail it in, either that or those old thin metal P clips, whack a nail in then fold its over the cable and through the buckle
young people today, they dont know they're born!!
Those are stick on, but with the cable collapse under fire concerns are they not making the metal style again for T&E fixing?i got a box of them in the van. you can still buy them, well, similar
they make metal cable clips, but they aint cheapThose are stick on, but with the cable collapse under fire concerns are they not making the metal style again for T&E fixing?
Are you rewiring as well?Hi, I know that whoever takes the job on is going to have a hard time pulling the cables out of the back of old fusebox as some monkey back in 78 "stapled" twin and earths to plasterboard woodwork, as seen with snakescope! In view of what you said I shall just free up the cables thru light switch back box opposite, never seen such meaty staples!
they are stick on, but you can nail them. i'd not rely on stick on anyway, fire or no fire.Those are stick on, but with the cable collapse under fire concerns are they not making the metal style again for T&E fixing?
Even with light instrument wire those sticky pads move/detach after a couple of years with even a little force.they are stick on, but you can nail them. i'd not rely on stick on anyway, fire or no fire.
you may be wrong there. if you are 17th ed. or even 18th. qualified, in the case of new build where building control is already involved, usually just giving BC a copy of your quals. will allow you to install and certify, email them a copy of the cert. have a word with BC.@killerjoule is just not really worth, is what the chaps are saying. I am a qualified electrician. I was in a Scheme up until 2 years ago, and regularly changed CU's, in my business.
Fast forward two years, I don't have the latest BS7671 C&G qualification, and no longer in a Scheme.
I have planning permission & building regs approval for some building work on my property. I will need my CU moving & probably replacing, along with some new circuits. Of course I could do it myself, and would like to.
However, it wouldn't be worth the hassle to prove to my LBC, I was more than capable. So I will be getting and electrician in.![]()
