- Jun 21, 2020
- 5
- 3
- 50,033
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
- Business Name
- Mr
Hi,I want to install a twin socket to a shed.The shed is of wooden construction and approximately 6m from the garage.I can't go underground due to a tarmac drive,so will have to go overhead.
If i install a catenary wire between shed/garage,can i then use twin and earth between the socket in the garage(pick up)and run this across to the shed to feed an RCD socket.
Thanks in advance for any advice.
