Sep 8, 2008
south wales
Anyone know of a junction box that will go through a 35mm hole. I have to install e.ergency downlights. Cannot gain access above ceiling. Cheers
The Wago lighting junction boxes are quite small, but off-hand no idea if they are less than 35mm across the diagonals.
[automerge]1592663212[/automerge]
Nope, just looked it up 29 x 39mm :(
The 'Quickwire' range might fit the bill!
No idea how available they are, but this appears to fir the bill:
Reactions: ipf and DPG
Quicwire see.s to tick all the boxes. Cheers.
Quickwire are only for t&e, so if switched maintained with 3c&e won't be any use.
Why do you need a joint box ?
We've used what I think are the same emergency lights and only the quick wires fit in the hole (just).
Cheers, used the quickwire like you said only just fits, but did the job.
[automerge]1592932629[/automerge]
Reactions: DPG and richy3333
They look pretty decent..... no good if you need hr flex for the light fitting, if required. Most led fittings have facility for terminating T+E, though, these days. About £3.50 apiece, not bad.
Available from one of the forum sponsors at £3.59 incl.
south wales
35mm Downlight
UK
kendo57,
Timbo,
