Good evening all
3 buildings :
1 Gf flat and 1St fl flat year 1915
2nd 6 flats year 1980
3rd cottage year 1900
They are separate buildings probabley 2in between them, 1 landlord owns all,
I ve done EICR on 1st building and 1 flat in 2nd building and found that the mains smoke detectors are interlinked hard wired between buildings no local isolation in buildings and not come across the power source that supplies them.
? What code
? Am I going mad is this allowed
I'm still trying to get my head around the statement that there is only 2in between the buildings?
Op, do you mean there are Aico hard wired and interlinked smoke alarms in a house that is now two flats, and then a few doors down the street with neighbours in between, there is another house converted into flats with smoke alarms on the same circuit? And you do not know what house even powers this circuit?
Just to a extra point to say separate buildings and cannot see how and where the cables go from building to building as the floor and roof levels are are different heights.
3 buildings next to each other nobody in between and yes to rest
If it’s tested out fine. It’s safe for continued use. No code.
possible an observation only, but bs7671 doesn’t care if there interlinked or not. It doesn’t care if the smokes don’t work. It’s the hard wiring and safety your ascertaining.
But does bs7671 have anything to say about a circuit running through several properties (regardless of what equipment it is supplying)? I think that is the original question rather than whether or not the smokes were interlinked and working.
Seems strange that except for the requirement of notice's of alternative supplies and where to isolate them, I can't find anything that would mean it was against regulations, your challenge for the rest of the week-end is to prove or diss-prove this, off you go, my OH has just opened a bottle of red.?
Reactions: Deleted account
thanks all for response, have already put on the ecir F/I and alternate supply to cover myself on the 4 flats already done, update further if I do come across the supply at moment loop impedance taken from each smokeand noted on each cert. thanks again
Be interested to know if there's different phases in each building. Might be a way to work out which building actually feeds them
Reactions: streamer
Your loop impedance results could give you a clue as to where they're fed from too.
Reactions: Stevie g
C
4K
ChrisElectrical88
C
Stafford
EICR today Mains smoke detectors interlinked
Stevie g,
streamer,
