Discuss EICR cables behind gas pipe. in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Came across this yesterday on an EICR. Cables and pipe were boxed in with MDF which, when removed, revealed some quite untidy cabling (although the cables all seemed secure enough when tugged) which also passed behind the horizontal gas pipe. I can't find the relevant reg number, but it is it deserving of an observation that the cables are threaded behind the pipe?
Thanks.
I must admit to being a little perplexed by these questions.
Without wishing to seem unkind, anyone who is carrying out inspection and testing should have a sound knowledge and expertise relevant to the nature of the installation being inspected and tested, and of BS7671, and other relevant technical standards. The answers to these questions should be immediately obvious. Even if you don't know the exact regulation, you should have to hand, and be able to locate the relevant regulations.
Another bloody rats nest of twin and earth lashed with with no care on a relatively new looking installation...they couldn’t even be bothered to trim and dress the tails to a neat looking lengthy :(
As far as gas pipes are concerned I’m sure is 25mm so in real life situ so long as they aren’t touching
Reply to EICR cables behind gas pipe. in the UK Electrical Forum area at ElectriciansForums.net
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
I'm following a spark who used an existing Panel Heater circuit, for new gas boiler circuit 6 months ago. The panel heaters were removed, so it's...
6K
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
I had the first EICR done on my flat last week, which failed with some C2s for having an older (2001) plastic consumer unit with no RCDs, but...
I'm having a bit of a disaster at the minute and would like an honest opinion. I am having a gas stove fitted in the corner of my room and...
