Discuss Hi Guys, is there a requirement for the metre isolator switch to have metal enclosure? in the UK Electrical Forum area at ElectriciansForums.net
Ok, I'm going to question this.
421.1.201 Within domestic (household) premises, consumer units and similar switchgear assemblies shall comply with BS EN 61439-3 and shall:
(i) have their enclosure manufactured from non-combustible material, or
(ii) be enclosed in a cabinet or enclosure constructed of non-combustible material and complying with Regulation 132.12.
Aren't the isolators classed as the above?
I tried to find the BS number for the Wylex 2 way isolator but couldn't find it on a few sites.
If there was then the meter would have be metal enclosed as would the cut out.
And Henleys and the like.
The meter and associated equipment is the responsibility of the network and supplier. They have special powers that prevent their equipment from being inadequately installed or catching fire.....
Reply to Hi Guys, is there a requirement for the metre isolator switch to have metal enclosure? in the UK Electrical Forum area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Should a small 500W electric rad on a fused spur also have an isolating switch? Some of these small rads have fancy timers that might get...
Hi all, I'm installing a temporary supply to a modular kitchen and need to bring over a new 3PN supply for a new temp consumer unit located...
I haven't seen a lot of discussion on this subject and have questions pertaining to isolation where TN earthing is present and any peculiarites...
