Z
zatchsmayr
I have purchased a 16 mm 10 watt Cree LED (XM-L2) and a constant current voltage driver, the spec sheet for the LED has a maximum of 3 amps. I limited my driver to 2.5 amps connected it to the 12 volt battery in my car. Now the led worked when I powered on my lights normally but when I locked my car and the parking lights flashed, it burned out. Is it because my voltage was not limited?
