Jun 10, 2019
54
25
93
Milton Keynes
Trainee Electrician
AFDD are manditory from the 28th of March on fixed final circuits using current carrying equipment not exeeding 32a People opinions on this. Also if a house doesn't have an afdd what would you code this as on a condition report ? Basically every Circuit would have to be an rcbo afdd at £130 a breaker that's alot of money per Circuit.
Has it definitely been confirmed that it is in the version?
Reactions: timhoward
Crikey OP! Don't go scaring us like that with uncertain certainties! 🥺
I just can't see any justification to fitting £135 arc fault breakers
Standard 8-10 circuit board swap with labour and arc fault breakers, looking at 3 grand with fitting
ridiculous
Leaving practical application to one side, AFDDs cost a lot of money as demand is low. If they became a mandatory requirement, it is without doubt that prices would drop by a significant percentage within a few months.
This shouldn't be news to anyone in the industry as it's exactly what happened with every other development, over many years; for example MCB, RCD, RCBO, SPD etc
How many members here have actually seen arcing result in a fire that didn't self extinguish before the flame left the accessory/consumer unit or whatever where it started? I can only think of one example and that was that national trust property that burned down. You know, the one where they saw smoke coming from a distribution board, no visible flames, but didn't switch it off, or attempt to stop the fire in any way... The one where electricians got blamed for not tightening a factory made, and sealed with paint, connection.
Well that goes against price theory, if demand is low the price should be, demand high then the price rises.
Reactions: nicebutdim
I remember fitting some RCBOs at my own house when they were literally just come onto the market and they were only £20-25 way back then. These were MK ones.
If demand rises then they sell more and so the price comes down. Expensive things are the ones that only sell in limited numbers.
I get where you're coming from, but that would apply when a surplus of goods builds up due to low demand or high demand outstrips supply. In the case of AFDDs it's unlikely that manufacturers were churning them out on large numbers when little demand existed, but still have significant development and tooling costs to recoup. At this time AFDDs designed to fit UK distribution boards are a niche product, developed to meet anticipated future demand.
Reactions: pc1966
I did a pre ammendment webinar with NAPIT, they have seen the final release but were not allowed to show what it was but was told AFDD has been rained back from the public comment version and now will only be required in certain circumstances, so suspect high rise buildings and maybe HMO's etc, might even include wood framed houses...
This would make much more sense , targeted use of AFDDs
Reactions: pc1966 and DPG
AFDD are only required on high risk residential buildings is the last and only update the IET gave ,everyone who has seen the new regs has signed non disclosures , so we wont actually know till the 28th March 2022
So that would be 90% of new builds since 1990!
Is it that high? I thought it would be a lot lower than that. I'm sure most new builds in our area were brick/block in the 1990s and into the 2000s.
Most of those I have seen are a timber frame, with block (drydashed) and stone block highlights, or brick outers.
My own, built in the 90's is just like this, big on insulation, but all inner side walls are plasterboard on the timber frame which forms the inner course - no double course of block or brick.
Perhaps it's a locality thing, but all those I have seen being built in West lothian and surrounding areas are like this.
S
10K
R
Milton Keynes
Trainee Electrician
Ammendment 2 AFDD BS7671
Ashley-Joseph,
Markyd,
