Discuss Serious issue - missed by people in the UK Electrical Forum area at ElectriciansForums.net
baldelectrician
Mentor
Went to an EICR yesterday to a let property that was tested 5 years ago (and apparently passed) 🤭
See how long it takes you to notice - the red box will be a give away 😀
The Wylex RCD was also noted as a C3
Clue: Cilla Black
That looks like someone thought they’re do that as an experiment, to see if it still worked… and then forgot to switch it back….
Been like that since mr G Anderson checked it in 2011?
Also looks like wylex is an exact copy of Sector… or vice versa.
Would this affect the meter reading at all? (Lower? Just a thought ) 😉
A WTF moment. It must have been deliberate, but why?
I think you may be underestimating the human brains capacity to do daft things without noticing. :D
The only reason I can think of for it being deliberate is that the tails are too short to reach the correct terminals but everything is sealed so would imply a meter fitter either did it or didn't notice it.
I think the middle two meter terminals are just a link anyway, and together with the nearest PME link, I don't believe it would affect metering in any way. Apart from the undersized conductor, the other issue is the isolator is only providing 1 pole isolation.
I'd say whoever fitted the isolator fitted the connector blocks, and their right leg is two inches shorter than their left.
Most likely a smart-meter installation mistake?
G Anderson would have only been there to check the consumer unit as part of the Wylex faulty MCB campaign those labels were supplied by Wylex who paid £75 + the cost of any faulty MCB's replaced for every checked consumer unit that was supplied between certain dates when the fault was found
It still doesn't excuse the fact that it was not brought to anyones attention though
Reply to Serious issue - missed by people in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Evening all. I did an EICR recently and then changed a consumer unit. As part of the EICR process I take off around 25% of all accessories to...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
I posted last week regarding a lighting cable being too short in the wall to reach my new light fittings.this is still annoying me lol, I will try...
