Nov 21, 2018
Rhyl
Hi Guys.
Is it safe to use an extension lead with a single pin 48V battery charger for an e-trike? The charger has a standard UK 3-pin mains plug. If so, what length limitations would there be for the extension lead - I probably won’t need it to be long. This is the Battery Charger:
Hi Guys.
That will be fine. Just buy a decent quality branded item from a reputable source. Avoid Amazon/ebay etc.
What ratings are on the spec plate of the charger?
Reactions: Spoon
Upvote 0
Thank you for replying. The charger is on order. Can I get back to you with the plate details when it arrives, please? Any advice on max length of extension lead?
Upvote 0
A better question would be 'how long do you need it?'
Are we talking just a few metres?
Upvote 0
Yes, not more than a few metres. To stretch from a standard wall socket out into the middle of a standard-sized garage where the e-trike will be.
You won't have a problem with that.
Reactions: Willie16
Upvote 0
Willie16,
DPG,
