dectwenty
Hello,
Looking at changing out my gas hob for the PIV851FB1E Bosch Induction Hob.
The Induction hob is 7400W and by my calculations this would be 7400/230=32.2A
Was after advice on the best method for install.
Can this be powered direct from the CU with appropriate MCB or is it necessary to have a cooker switch adjacent to the induction hob. Either at worktop level or in a cupboard underneath.
The distance from the CU is around 15m and the cable would be clipped to the joists under the flooring. At the wall it would be behind the plaster board.
Would appreciate advice on appropriate MCB size and cable diameter etc.
Thanks in advance for any advice given.
