- Jul 2, 2023
- 19
- 6
- 33
- United Kingdom
- Trainee Electrician
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the tray using:
I’m just a bit confused about how this should look and which parts should be on the “inside” where the cable runs on the tray and the outside (if that makes sense)?
Just don’t want to drop marks or even fail because I’ve in correctly used P clips as I’d find that quite embarrassing to say the least.
If anyone could please explain how this should look or even any pics I’d be really grateful, AM2’s on Monday and I have enough to worry about as is other than P clips.
- P Clip
- Nut
- Washer
