- Jun 18, 2024
- 3
- 10
- 3
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
I was trying to fix a cold radiator when I came across some exposed cable and copper wire under the floor boards, a quick test with a voltage pen showed live. Not sure what kind of voltage they're putting out, wouldn't the RCD trip if they were dangerous? I covered the ends with electrical tape for now.
If any electricians can give some advice please, especially those covering the Bishop Auckland area.
Cheers.
Cheers.
