Discuss socket and switch heights in the Electricians' Talk area at ElectriciansForums.net
M
multicore
Hi all, i'm new to the forum but would like to get a thread going. I,m wondering if the minimum 450mm maximum1200mm heights have changed recently if so what are they also has there been a change to the 350mm from internal wall for sockets?
:confused:
Think that App Doc M only applies to new builds, when adding sockets or moving switches etc in existing installations I either put them at the same height as the existing accessories or where the customer wants them.
When doing extensions or loft conversions tend to go for the M heights unless customer says different, after all they are going to be using the accessories and as far as I am concerned if they are paying they have them at whatever height they would like (within reason of course).
Regards WA
Well done john , as has been said you can put sockets at any height between 450 and 1200 and switches no higher than 1200 ,but for new builds , i have installed them at the new heights on some rewires where walls have been chased
it's quite a good height actally. my knee is just 450mm, and my left nipple is 1200mm. no need for a tape measure
Cheers guys I gotta say that the exam questions were a hell of a lot easier than the past paper questions but passing it has booked my place to do the 2392 after christmas
Reply to socket and switch heights in the Electricians' Talk area at ElectriciansForums.net
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
