Discuss Thermal insulation in floor void in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rryles
Rewiring a 60s house. Loft has 270mm of insulation. Ground floor is solid. First floor is going to have wet underfloor heating installed so will have insulation stuffed into the void. Joists are 200mm deep. Seems I will have to run a fair few cables in the first floor. Am I correct in thinking this will be reference method 101? Also, it might be possible to avoid the insulation by using the safe zone at the top of the walls. I know that's to the regs, but I worry that it isn't what Joe Blogs with his drill would expect. Damage to decoration isn't really an issue.
i have same problem with my customer he loves his insulation
It is regarded as safe as the circuit will be RCD protected.
I'm afraid I'm old school and both that method and the"V" in the wall method to me is quite inanne. How many home owners know where safe zones are, but a good majority will sort of take note that if there is a socket or switch there, there is a good chance cables might be running to it, espicially vertically.
So no the safe zone 150mm from ceiling would really be a last resort thing, but that is just IMO
Reply to Thermal insulation in floor void in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi My 4 bed 2 storey house was extended 2 years ago and completely re-wired, but I am having to upgrade the insulation and board out the loft...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Hello, I'm about to start a complete house refurbishment, including rewiring and insulating between floors. As I understand it building regs...
I am planning a rewire of our 1960s bungalow, for power sockets running cables under the floor. There is a 200mm floor void over a concrete...
