Currently reading:
shower to notify or not
Discuss shower to notify or not in the Australia area at ElectriciansForums.net
M
mrmatt
A friend of a friend split up with her partner and he took the shower with him when he moved out leaving wires hanging out the wall. The local council were called and the circuit was disconnected from the consumer unit as a safety precaution. A plumber has put in a new shower and she has asked me to connect it back up at both ends and test.
Providing the calculations work out ok she wants to use the cable alreadt there as she dont really want the floors up. is this a notifiable job or would you class it as a like for like?
Can I stick my oar in?
In this scenario, because the old shower had previously been removed and the circuit had been made safe a MWC must be issued, but not notifiable.
If the shower was still in place, broken and a direct replacement was being fitted it could be interpretted that any tom, dick or harry could make the change and no notification is required.
A registered electrician, in either case, would at the very least check the circuit and issue the home owner with a MWC, but not notify.
Don't we all love the ambiguity of Part P!
maybe it is time for ALL electrical work to be made notifiable (sure niceic ect would love that lol)
the reason how many times do you go to a job where an old bugger (usually) has disconected a light switch or fitting and rewired it wrong before ringing?
I am only thinking of the public honest lol not the extra work.lol
I 100 percent agree with you, save all this fuss an nonesense whats notifiable and what isnt, notify all work done, no confusion then, think it mite put prices up, but hey- everything else is rising!!!
You cant be sure its a like for like replacement because the oringinal shower is not there, you only have the househoulders word on the size, the existing cable should be the required size for the new shower and changed if it is not suitable, as you will be connecting a circuit to the fuseboard the mcb needs to be correct for the circuit and it will need testing & notifying, you cant say its like for like if you have never seen the existing shower. (unless you can locate the original shower?)
if the cable is sufficient for the new shower, then rating wise, i would say it,s like for like. as you will be reconnecting a circuit, yes, test and MWC, but i would not consider it notifiable. that is only my personal opinion.
Connecting a circuit to a fuseboard is notifiable, don't forget it was the council who disconnected the circuit, i would advise notifiying.
Thinking about it connecting new circuits is notifiable, but without the existing shower it would be an alteration to an existing circuit in a special location, therefore notifiable.
I have 2 opinions on this. If you are Part P registered then notify it. If you are not then reconnect the shower at both ends, assuming you are a qualified Electrician with the knowledge and test equipment to test and certify it then do it, issue a MWC, and state on it that it is a direct replacement for a failed unit. If you have to install a RCD because it doesn't have one then you are altering the circuit and means of protection, so it will need notifying whatever. I can't see you having a problem not notifying a like for like replacement if you back it up with the relevant BS certification.
Cheers.........Howard
The rules that I know from being upto date with the regs is that you can replace a like for like in a Special location and NOT have to notify LABC. But as you don't know what the previous Shower rating was as long as the new shower doesn't require an upgrade of the protective device then all you are Basically doing is an Alteration of that circuit ( feel free to Correct me if im wrong by the way).
And to one of the above posters who said that all work should be notifiable *You can't actually be serious Electricians are getting ripped off left right and center as it is Making Sparkies notify every single bit of domestic work is only going to benefit NIC/ELECSA/Napit fat cats
a qualified competent Electrician should not have to *Notify* his/her own work Thats why we go to College and do Apprenticeships so we learn how to Install and repair and choose the Right equipment for each job in a safe and competent manner.
a qualified competent Electrician should not have to *Notify* his/her own work Thats why we go to College and do Apprenticeships so we learn how to Install and repair and choose the Right equipment for each job in a safe and competent manner.[/QUOTE]
Well said John, and your opinion is shared with thousands of other Sparkies throughout the land. if only the nuggets who make the rules would listen.
I totally agree BUT there are many unqualified cowboys out there who wouldn't even know what the big red book was, I think to most people electrics can look much less complicated than they are. Connecting a gas boiler to the gas looks easy but I wouldn't do it but my dad did 20 years ago with no qualification to do it, he also did some very dodgy wiring that thank god I sorted out a couple of years ago like a radial 120M extention to his garage to supply his power tools welders ect and lighting wired in 2.5 on 32amp . but anyway hope this makes sence lol
Paul
Cheers.........Howard[/QUOTE]
SORRY QUOTED WRONG THREAD
Paul
That's why building control rarely take court action, because if someone wins and sets a precedent it will blow an hole in revenue for the scheme FREELOADERS.
Yep i agree to howard ,but when you see diy store selling every thing from fuses to CDU's every ones going to have a go all how often do we see it on site and on here too ,in principle Part P was a good idea but , if you are qualified and inspected as we are then why notify it just costs the country yet more mone for what ,in my eye the regs should become statutory and you should not be able to work on electricity no matter how bigger job unless your regestered as you do with gas ,at the end of the day how many people are killed and how many houses are burn down with house fire caused by electrical faults ,gas you can smell , electricity you cant or even see it unless its a lamp
Reply to shower to notify or not in the Australia area at ElectriciansForums.net
