Discuss how to wire a pipe stat in the Central Heating Systems area at ElectriciansForums.net
S
simon mcnamee
I am looking to wire a pipe stat to my stove but dont know how to wire the junction box that the pump and stat go into, it would be well appreciated.
Is this a new install or existing. Do you know what you are trying to achieve by installing a pipe stat? Do you know how the system is plumbed? Not enough info provided.
Should we all get our crystal balls out and find out.
This is not the first and will not be the last where people ask questions without giving enough information. I thought most people on here where elctricians not clarevoyents.
the pipe stat is wired and the pump, i was told to run the both into a junction box but the pump just stays on and doesn't come on when at the chosen temp.
the pipe stat is a switch. when the pipe gets to a certain temperature the switch will close. permanent live one side of the stat, switched return from the stat will join to the pump. neutral straight to the pump. hope that makes sense.
like what mark says, or when the pipe gets too hot, the stat opens and the pump stops.
Simon, I started to do a drawing for you but my judgement got the better of me. You obviously don’t know what you’re doing, please get someone that does!
Sorry if that sounds harsh but I will not be a party to giving information that could be misinterpreted.
have to agree, what you describe won't get you noticed for the latest NASA project, do you have a specific sticky point?, cause if you do ,fire away, i will help.
The problem being our OP hasn’t a clue either, that’s why I’ve washed my hands of it.
The last time I fitted a pipe/cylinder stat it came with good easy to follow instructions. OK as electricians we would take it for granted as to how to wire it up.
I don’t want to be accountable for a novice.
Unfortunately there are several wiring systems and many more pipe stats & they use different connections, also we have no possible way of knowing how your Junction is wired to the rest of your system. Please get an Electrician in, it will be safer in the long run.
i'm going to fit a cylinder stat . Is it ok to wrap it round the header tank in the attic ?
Lol. I went to an S plan the other day. No hot water. Both valves at the boiler and whoever wired it couldnt be bothered to run a cable to the cylinder so they fitted the Cyl stat on the pipe just after the hot water valve. Brilliant!!
Much better to play it safe. Get somebody who knows how to do it and observe how he does it so that next time you will know what to do.
If he gets someone in to do the job properly / safely then it should'nt need doing again. Just watching someone doing a job once does'nt make you competent to do the job yourself, Electrical work like Gas should be left to people who know what they're doing & have the test equipment / knowledge to prove it's safe on completion. Electrocution can be pretty final:shocked:
hello, well after reading this amusing thread :shades_smile: and for the record I will say I am a qualified gas engineer with part p and 17th edition qualifications, and I have two installations both with solid fuel stoves connected to c/heating systems having a pipe stat wired correctly to switch on a pump at 40 degrees which it does... however the stat opens when pipe gets much hotter so switching off the pump...causing kettling and venting this is not a condition we want.. so how does one remedy this ?
If one then turns the stat to 80 degrees or so the pump will then run again .. this is not how the stat is supposed to function when wired to close during rising temp... Should it not stay closed until temp drops below 40 degrees and then switch off the pump ?:stuart:
Additionally, when the fire goes out and the temperature drops below 40 degrees the stat fails to open leaving the pump running when it ought to have switched off.... The stat used are the Salus pipe stat ...
Any and all comments most welcome... even sarcastic ones :crazy:
Thanks guys
If this is a solid fuel stove/ boiler we normally wire a "cold start" stat set at 50c on the flow heating near the boiler and a high limit stat set at 90c on the return circulator near the boiler. The "cold start" stat will bring the pump on at 50c if the room stat and programmer are calling for heat and put heat through the radiators. This, according to manufacturers, will prolong the life of the boiler by not circulating cold water through the stove. The high limit stat will turn the pump on if the return from the cylinder reaches 90c to prevent the system over heating and heat is dispersed through radiators. We use Honeywell pipe stats and wire permanent live to C and live feed to pump from 2, and as temperature rises the stat switches on the pump, if used the live to the "cold start" can come from a programmer and /or room stat.
Hope this helps.
Hi Guys thanks for your eply.. wired to C1 .. however it does appear from chatting to some others in the industry that there are two types of pipe stat.. some break on rise and some make on rise.. and it appears the Salus and honeywell stat in use break on rise.. hence the pump switches off at the preset temp... Durrr !!! .. Oh to have a brain that works all the time eh ?.. so the anser in short which may help the other guy is buy a sta that "makes on rise".. problem should then be solved .. will confirm when I have put this into practice.. Thanks again
All the best
Clawhammer
All the best
Clawhammer
Change the wire from C1 to C2 should be job done according to Salus diagram.
Hello, Yes Thank you Very much Had realised that C 2 was solution.. The confusion arises from the wording reverse logic.... c2 says breaks on temp drop... brain says, want it on, on temp rise off when cold.. same thing but must be age thing .. hahah
Thanks again will surely help the other guy anyway
All the best
Clawhammer:happy:
Reply to how to wire a pipe stat in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
So I’ve been having this issue with my boiler for a while now, I’ve currently got one stat in the hall that when I turn it on it brings the...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
